HOW TO
Check if SQL Server and SQL Azure Connections from ArcGIS clients are encrypted
Last Published: August 28, 2025
Summary
To ensure encrypted communication between ArcGIS Server and/or ArcGIS Pro and Microsoft SQL Server, configure the enterprise geodatabase connection string with the parameters Encrypt=yes;TrustServerCertificate=yes in accordance with the guidelines outlined in the ArcGIS Pro documentation: Encrypted connections to SQL Server databases
Procedure
Using SQL Server Management Studio, execute the following database query to verify that the client session connection is configured with ENCRYPT_OPTION = TRUE.
SELECT session_id, connect_time, net_transport, encrypt_option, auth_scheme, client_net_address
FROM sys.dm_exec_connections;
Confirming the connection properties in SQL Server Management Studio
Article ID: 000036738
Software:
  • ArcGIS Pro
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
