PROBLEM
Characters in the results of an 'identify' operation performed in a Web Mapping application appear 'garbled'
When an identify operation is performed against data referencing a domain containing international character sets (such as Greek, Arabic, Cyrillic, etc.), the resulting output may be formatted improperly using ASCII based characters.
Cause
The local ArcGISSOC account has not been configured to use the regional language required.
Solution or Workaround
To address this issue, use the 'Regional and Language Options' tool in the control panel to set the ArcGISSOC account to use the desired language.
  1. Log into the ArcGIS Server machine under the local ArcGISSOC account.
  2. Open the Windows control panel and double-click 'Regional and Language Options'.
  3. Use the drop-down list to define the appropriate locale. If the language in question is not listed in the drop-down list in the Regional Options tab, the supplemental language pack may be required to be installed. Click the 'Languages' tab and select the appropriate language pack to install. A restart may be required for the changes to take effect.
Article ID: 000010919
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
