HOW TO
ArcIMS uses predefined ports to communicate between the Application Server and Servlet Connector and the Application Server and Spatial Server.
The default ports are:
5300 for communication between the Application Server and Servlet Connector.
5353 for communication between the Application Server and Spatial Server.
You must restart the ArcIMS services for the port modification to be read. If you have altered the Spatial Server port value, restart the ArcIMS Monitor Service on the machine where the Spatial Server is installed.
Summary:
Stop them in the following order:
A) ArcIMS Tasker
B) ArcIMS Monitor
C) ArcIMS Application Server
Start them in the opposite order you stopped them:
A) ArcIMS Application Server
B) ArcIMS Monitor
C) ArcIMS Tasker
For further information about the stop and start of ArcIMS services on Windows or Linux operating systems, see the articles listed in Related Information below.
iPlanet Web Server 4.0 (with Native Servlet):
<iPlanet installation directory>/docs/servlet
Netscape Enterprise Server 3.6 (with Native Servlet):
<NES installation>/suitespot/plugins/java/servlets
Note: If you are using Netscape Server 3.x, copy this file to:
<Netscape Install>/suitespot/http(s)-<Web server>/config
Apache JServ 1.0 for Apache Web Server 1.3.9:
<JServ Installation directory>/servlets
AppServerMachine=<machine name>
AppServerClientPort-5300 **Change port number
ConnectorPort=5300 **Change port number
RegPort=5353 **Change port number
$JAVA_HOME/bin/java -cp $AIMSHOME?Monitor~com.esri.mtier.Imsmonitor
$AIMSAPPSERVER 5353 $AIMSHOME/bin DEBUG >~
$MONITOR_LOGFILE 2>&1 &
Summary:
A) ArcIMS Tasker
B) ArcIMS Monitor
B) ArcIMS Monitor
C) ArcIMS Tasker
All associated ArcIMS files will be updated automatically with the new port numbers
Article ID:000002035
Get help from ArcGIS experts
Download the Esri Support App
