HOW TO
This article shows how to modify the View.Identify system script to change the default size of the Identify window.
Code:
myIDWin=IdentifyWin.The
myIDWin.Resize(400,400) 'experiment with the pixel parameters.
You can increase or decrease the size of the window by specifying larger or smaller numbers in the Resize parameter. The first number is the width of the box and the second is the height.
Article ID:000002755
Get help from ArcGIS experts
Download the Esri Support App
