HOW TO
You can add to or remove the two choices on the right-click menu of the Java Custom Viewer’s legend.
When the Java Custom Viewer is created by ArcIMS Designer, two choices are on the legend’s right-click menu, Zoom to Active Layer and Use In Overview Map. You can disable these choices or enable other choices by editing the web site’s default.js file.
Open the web site’s default.js file in a text editor and uncomment the following line in the function init
Code:
setupTOCPopupMenuItems();
Article ID:000002207
Get help from ArcGIS experts
Download the Esri Support App
