HOW TO
Change ArcGIS object store from cluster mode to a single data store
First Published: December 12, 2025
Last Published: December 12, 2025
Summary
After installing ArcGIS object store in cluster mode, the following steps can be used to change to a single instance mode before creating content.
Procedure
To change the ArcGIS object store to a single datastore from cluster mode.
  1. Go to Programs and Features in the Windows Control Panel.
  2. Click ArcGIS Data Store.
  3. Click Change.
  4. Choose the Modify option.
  5. Click Object Store so you see an X on it.
    • If you get a message about removing it, proceed.
  6. Once finished, repeat steps 4 and 5 above, this time clicking on Object Store to reinstall (this should remove the X).
  7. After the previous step finishes, run ArcGIS Data Store Configuration Wizard to configure the object store
Article ID: 000039175
Software:
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
