PROBLEM
Centroids are placed outside of polygon boundaries in ArcGIS Online
First Published: April 25, 2018
In ArcGIS Online, when creating centroids for polygon features using the Find Centroids tool, the centroids are placed off-center or outside of polygon boundaries.
image of Centroids outside of polygons
Cause
The Find Centroids tool is run on complex polygons with the true centroid option enabled. The centroids are created at an average position relative to the vertices in the shape, but not necessarily within it, as shown in the image above.
Solution or Workaround
When using the Find Centroids tool, select the option contained by input features in the Show me output locations parameter, and run the analysis. This results in output centroid points located inside or contained by the bounds of the input feature.
Select contained by input features in Find Centroids
Article ID: 000017716
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
