PROBLEM
Cannot zoom to the maximum zoom level in Map Viewer
First Published: July 9, 2024
Last Published: August 21, 2024
In ArcGIS Experience Builder, when multiple basemap layers have been added to a web map, you are no longer able to zoom to the maximum zoom level.
Cause
The Map Viewer zoom limits are defined by the basemap that is listed last.
Solution or Workaround
To set the zoom limits to that of a different basemap, reoreder the basemap layers so that the basemap with the required zoom limits is listed last.
Additionally adjust the Visible Range in the Visibility Properties for the basemap layers to achieve a seamless change between each basemap when zooming in or out.
Article ID: 000033070
Software:
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
