BUG
Cannot use datasets from Oracle 11g or Oracle 12c R1 with multiple geometry fields in Insights for ArcGIS
First Published: April 10, 2019
Adding a dataset from an Oracle 11g or Oracle 12cR1 database will fail in Insights for ArcGIS if the dataset has multiple geometry fields and has multiple entries in USER_SDO_GEOM_METADATA view.
Cause
This failure is caused by an issue in Oracle 11g or Oracle 12c R1 databases.
Workaround
Upgrade your Oracle database to a newer version.  For more information on which Oracle versions can be used with Insights, see Supported databases.
Article ID: 000020718
Software:
  • ArcGIS Insights
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
