PROBLEM
Cannot select a certificate when using PKI authentication for ArcGIS Insights desktop on MacOS
First Published: February 17, 2022
Last Published: February 17, 2022
When opening a workbook in ArcGIS Insights desktop for MacOS that contains a dataset from an organization secured with PKI authentication, you will be asked to sign in to the organization to access the layer. If the workbook contains datasets from multiple organizations with different authentication methods (for example, IWA or SAML), then the PKI login modal will be blocked. The datasets requiring authentication will return a 'Something went wrong' error.
Cause
The authentication window is blocked when accessing data with different authentication methods on Insights desktop with MacOS. Therefore, it is not possible to add a security certificate.
Solution or Workaround
Sign in to all of the connections for organizations where you are accessing the data before opening a workbook. If you are signed in to the connection, then you do not need to sign in to access the data once the workbook is open.
Article ID: 000027231
Software:
  • ArcGIS Insights
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
