ERROR
Cannot run lmutil.exe located under C:\Documents and Settings\...utilities
Error Message
When trying to install the ArcGIS License Manager, the following error message is displayed:
"Cannot run lmutil.exe located under C:\Documents and Settings\...utilities"
Cause
The installer is not able to run on this path.
Solution or Workaround
Change the user environment variables TMP and TEMP to C:\temp.
Instructions provided in the Knowledge Base article, How To: Edit an environment variable, describe how to edit environment variables for various platforms.
    Article ID: 000010249
    Software:
    • ArcMap 9 x
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
