PROBLEM
Cannot preview an ArcIMS Image Service in ArcCatalog
An ArcIMS Image Service cannot be viewed in the ArcCatalog Preview panel.
Cause
The map units need to be set in ArcIMS Author.
Solution or Workaround
Perform the following steps to set the map units.
  1. Determine the map units of the data. This could involve going back to the source information for the data. Another possibility is to view the data with other data of known map units or read the metadata.
  2. Open the map configuration file (.axl) in ArcIMS Author.
  3. Click View Menu > Scale Bar Properties > Map Units and set the units to Decimal Degrees, Feet, or Meters. Save changes to the .axl file.
  4. Refresh the Image Service using ArcIMS Administrator. Now the service can be previewed in ArcCatalog.
Article ID:000005656
Software:
  • ArcMap 8 x
  • ArcMap 9 x
  • Legacy Products
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
