ERROR
Cannot load data from data source
First Published: May 5, 2016
Error Message
Using the Add Field tool located in ArcToolbox > Data Management Tools > Fields to add a field returns the following error:
"Could not load data from the data source. If you can correct the problem press the refresh button to reload data.."
Cause
This is a known issue when having the attribute table open in the background.
Solution or Workaround
There are two solutions.
  • Close the table before adding a field.
  • Once the error message appears, click OK. The tool will finish running, and the attribute table will go blank. Close the table and reopen it, and the new field should appear.
Article ID: 000007173
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
