PROBLEM
Cannot install ArcGIS 9 ArcObjects Desktop Developer kit
Last Published: April 26, 2020
When attempting to install the ArcGIS Desktop Developer kit for ArcGIS 9, an error may occur, stating that a previous version is installed. The previous version may not show up in the Windows Add/Remove programs interface.
Cause
Residual registry entries exist for the older version of the developer kit.
Solution or Workaround
Warning:
The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary.
Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
Remove the residual entries for ArcObjects Developer's Kit.
  1. Start the Windows Registry editor; click Start > Run, type 'regedit' and press Enter.
  2. Navigate to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\
  3. Beneath this folder, there are many folders with long, alphanumeric names. Find the folder named as follows:
    {52069752-B5E9-11D5-8110-00C04FA070E5}
  4. Remove this folder.
Article ID: 000006913
Software:
  • ArcMap 9 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
