BUG
Cannot edit SDE data with Python update or insert cursors
First Published: May 5, 2016
Update and insert cursors fail when trying to edit SDE data using a Python script. For example, the script below should edit field values in an SDE feature class. This code runs without error, however, the attribute values are not changed.
Code:
from win32com.client import Dispatch
gp=Dispatch("esriGeoprocessing.GPDispatch.1")
gp.workspace="Database Connections/Ora9204Helium.sde"
try:
table = "SYSTEM.rn_test"
rows = gp.UpdateCursor(table, "SHAPE.LEN > 20")
row = rows.next()
while row:
row.ATTR = 200
rows.UpdateRow(row)
row = rows.next()
except:
del rows
del row
Cause
This is a known limit. This is only a problem with versioned SDE data. If the data is not versioned, then the above code works as expected.
Workaround
A possible workaround is to use disconnected editing. This allows a user to check out ArcSDE data to a personal geodatabase. Once the data is in a personal geodatabase, insert and update cursors will work correctly. After editing is complete, check the data into the ArcSDE database.
More information can be found on Disconnected Editing in the ArcGIS Desktop Help. Select Building a Geodatabase > Disconnected editing on the Contents tab.
    Article ID: 000007454
    Software:
    • ArcMap
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
