ERROR
Cannot copy and paste a narrow network into a dataset requiring wide networks
First Published: May 5, 2016
Error Message
Failed to paste <Network_Name>
Cannot copy and paste a narrow network into a dataset requiring wide networks.
Cause
The geometric network was originally built in a narrow format that supports feature classes with IDs up to 9,999. A narrow network cannot be copied into a geodatabase that contains Class IDs in excess of 9,999. In order to contain classes with an ID of 10,000 or greater, the network must be rebuilt in the wide format in the target geodatabase.
Solution or Workaround
Drop the geometric network in the source geodatabase. Copy the dataset to the target geodatabase and rebuild the geometric network.
    Article ID: 000004575
    Software:
    • ArcMap
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
