BUG
Cannot convert CAD 3D curve entities to geodatabase true curve features
First Published: May 5, 2016
Converting 3D CAD curve entities to geodatabase features does not produce true curve features.
Cause
Neither ArcToolbox 'CAD to Geodatabase' tool nor the 'Export Data' command in ArcMap supports the conversion of 3D CAD entities (entities with z values) to geodatabase true curve features. Instead, the 3D CAD curve entities will translate into tessellated geodatabase line and polygon features.
Workaround
There is no workaround for this known limitation.
Article ID: 000003293
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
