PROBLEM
Cannot add two related tables in Map Viewer pop-ups using Arcade expression in ArcGIS Online
First Published: December 6, 2025
Last Published: December 6, 2025
In ArcGIS Online Map Viewer you can create pop-ups and include a related table of the hosted feature layer using an Arcade expression. However, you cannot add two related or multiple tables in a pop-up using an Arcade expression.
Cause
There are multiple limitations in ArcGIS Online:
  • Arcade in pop-ups only supports querying one related table per expression. Attempting to access a second related table either fails or returns empty results.
  • Limited formatting capabilities: Displaying multiple related records in a structured format (such as a table) is not natively supported
Solution or Workaround
While ArcGIS Online Map Viewer currently limits pop-up configuration to only one related table, an effective alternative workflow is available using ArcGIS Pro.
  1. Create Relationship Classes
    Use the Create Relationship Class geoprocessing tool to define relationships between your root feature layer and each related table:
    1. Input the Origin Table (root) and the (related) Destination Table.
    2. Choose a Relationship Type.
    3. Name the Output Relationship Class.
    4. Click Run.
Creating the relationship class
  1. Configure the pop-ups in ArcGIS Pro.
    1. In the Contents pane, right-click the layer and click Configure Pop-ups.
    2. In the Configure Pop-ups pane, click the Expression button, and click New to open the Arcade Expression Builder.
    3. Use Arcade expressions as in the example provided below to retrieve and format data from multiple related tables.
    configuring the pop-ups
    building the expression
    Code example:
    // Get related records from Dataset A
    var datasetARecords = FeatureSetByRelationshipName($feature, "Relationship_A");
    // Get related records from Dataset B
    var datasetBRecords = FeatureSetByRelationshipName($feature, "Relationship_B");
    // Initialize a string to hold the output HTML
    var result = "<h3>Debug Information:</h3>";
    // Debug: Check if datasetARecords is null
    if (IsEmpty(datasetARecords)) {
      result += "<p>Error: Dataset A records are empty or null.</p>";
    } else {
      result += "<p>Dataset A records count: " + Count(datasetARecords) + "</p>";
    // Debug: Check if datasetBRecords is null
    if (IsEmpty(datasetBRecords)) {
      result += "<p>Error: Dataset B records are empty or null.</p>";
    } else {
      result += "<p>Dataset B records count: " + Count(datasetBRecords) + "</p>";
    // Initialize output HTML for Dataset A
    result += "<h3>Dataset A Information:</h3><table border='1'><tr><th>Field 1</th><th>Field 2</th><th>Field 3</th><th>Field 4</th></tr>";
    // Check if datasetARecords has data
    if (Count(datasetARecords) > 0) {
      // Loop through related records in Dataset A
      for (var recordA in datasetARecords) {
        var attributes = datasetARecords[recordA];
        result += "<tr><td>" + attributes.FIELD1 + "</td><td>" + attributes.FIELD2 + "</td><td>" + attributes.FIELD3 + "</td><td>" + attributes.FIELD4 + "</td></tr>";
    } else {
      result += "<tr><td colspan='4'>No related records found.</td></tr>";
    result += "</table>";
    // Add Dataset B related data to the result
    result += "<h3>Dataset B Information:</h3><table border='1'><tr><th>Field A</th><th>Field B</th><th>Field C</th><th>Field D</th></tr>";
    // Check if datasetBRecords has data
    if (Count(datasetBRecords) > 0) {
      // Loop through related records in Dataset B
      for (var recordB in datasetBRecords) {
        var attributes = datasetBRecords[recordB];
        result += "<tr><td>" + attributes.FIELDA + "</td><td>" + attributes.FIELDB + "</td><td>" + attributes.FIELDC + "</td><td>" + attributes.FIELDD + "</td></tr>";
    } else {
    // Return the final result
    return result;
    1. Once the pop-ups are configured in ArcGIS Pro, publish the map or layer as a web layer to ArcGIS Online. The pop-up configuration is retained in the hosted feature layer.
    Article ID: 000037323
    Software:
    • ArcGIS Pro
    • ArcGIS Online
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
