PROBLEM
Cannot add an ArcGIS Server Image Service from ArcGIS.com to ArcGIS Desktop 10
First Published: May 5, 2016
The list that appears after clicking the Open menu below the thumbnail of an image service on ArcGIS.com does not include ArcGIS Desktop.
Cause
ArcGIS.com is missing an option to open image services in ArcGIS Desktop.
Solution or Workaround
To add the image service to ArcGIS Desktop, make a connection in ArcCatalog directly to the host server.
  1. Open the Details page for the image service and locate the Map Contents link.
  2. Copy the first part of the URL of the Map Contents link, up to and including the word 'services.' For example: https://www.example.com/arcgis/rest/services
  3. Open the Add ArcGIS Server dialog box inside ArcCatalog and paste the URL into the Server URL field.
  4. Delete 'rest/' from the URL. It should look like this: https://www.example.com/arcgis/services
  5. Click OK.
  6. Use this connection to browse to and add any of the services on that server, using the Add Data dialog box.
Article ID: 000011086
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
