PROBLEM
By default, the locally stored Canada 2023 Business Analyst dataset uses StreetMap Premium data stored in a modern mobile geodatabase. This format is optimized for ArcGIS Pro but causes a broken data link in ArcMap due to compatibility issues. ArcMap users can eliminate this problem by navigating to and selecting the streets network from the file geodatabase, stored in the downloaded dataset. Once ArcMap Business Analyst points to streets data from the file geodatabase, the broken link will be repaired and resolved.
To make this change, do the following:
Ensure that the Canada 2023 Business Analyst dataset is installed and licensed.
The Preferences window opens.
The Dataset parameters are displayed.
With a standard installation on the C: drive, the path to this feature class is:
C:\ArcGIS\Business Analyst\CAN_2023\Data\Streets Data\NorthAmerica.gdb\Routing\Routing_ND
Completing these steps resolves the broken data link in ArcMap and enables the street network for use in the downloaded Canada 2023 Business Analyst dataset.
Article ID: 000031460
Get help from ArcGIS experts
Start chatting now
