Frequently asked question
Code:
<xsd:complexType name="taglibType">
- <xsd:annotation>
<xsd:documentation>The taglibType defines the syntax for declaring in the deployment descriptor
that a tag library is available to the application. This can be done to override implicit map
entries from TLD files and from the container.</xsd:documentation>
</xsd:annotation>
- <xsd:sequence>
- <xsd:element name="taglib-uri" type="j2ee:string">
- <xsd:annotation>
<xsd:documentation>A taglib-uri element describes a URI identifying a tag library used in the web
application. The body of the taglib-uri element may be either an absolute URI specification, or a
relative URI. There should be no entries in web.xml with the same taglib-uri
value.</xsd:documentation>
</xsd:annotation>
</xsd:element>
- <xsd:element name="taglib-location" type="j2ee:pathType">
- <xsd:annotation>
<xsd:documentation>the taglib-location element contains the location (as a resource relative to
the root of the web application) where to find the Tag Library Description file for the tag
library.</xsd:documentation>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
<xsd:attribute name="id" type="xsd:ID" />
</xsd:complexType>
Code:
<%@ taglib uri="http://www.esri.com/argcis/webcontrols" prefix="ags" %>
Code:
<taglib>
<taglib-uri>http://www.esri.com/argcis/webcontrols</taglib-uri>
<taglib-location>/WEB-INF/arcgis_webcontrols.tld</taglib-location>
</taglib>
Code:
<taglib>
<tlib-version>1.0</tlib-version>
<jsp-version>1.2</jsp-version>
<short-name>a</short-name>
<uri>http://www.esri.com/arcgis/webcontrols</uri>
</taglib>
Article ID:000007719
Get help from ArcGIS experts
Download the Esri Support App
