PROBLEM
Cannot install Collector for ArcGIS on a compatible Android device through Google Play
First Published: February 7, 2018
Last Published: July 28, 2025
The functionalities of ArcGIS Collector, ArcGIS Explorer, and ArcGIS Tracker are now available in ArcGIS Field Maps. There are no new capabilities planned for these apps—all future updates will be focused on Field Maps. Migration is recommended. See ArcGIS Blog: Migrate to Field Maps for more information.
An Android device meets the Android Device Requirements for using Collector for ArcGIS. However, when attempting to install the app, Google Play returns a message stating that Collector for ArcGIS is not compatible with the device.
Cause
Google Play is incorrectly reporting that some compatible devices are not compatible.
Solution or Workaround
If experiencing this issue, install Collector for ArcGIS directly from Esri by following the steps in FAQ: How do I download Collector for ArcGIS without access to Google Play or the Windows Store?
Article ID: 000017573
Software:
  • ArcGIS Collector
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
