PROBLEM
After installing GeoSoft® extensions for ArcGIS 3.2, data can no longer be added to ArcMap from ArcGIS Online. The menu item used to launch ArcGIS Online is disabled (grayed out).
There is a bug in release 3.2 of the GeoSoft Extensions for ArcGIS (Target or Geochemistry) that conflicts with the code Esri uses to access ArcGIS Online servers. This may also cause some ArcGIS Add-In pop-up windows to fail to display.
Warning: The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary. ESRI cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
Note: The GeoSoft bug was fixed in release 3.3 SP2. If any earlier versions of the GeoSoft extensions were previously installed on the system, the above registry edits may still be needed to completely fix the issue.
Article ID: 000011454
Get help from ArcGIS experts
Download the Esri Support App
