Frequently asked question
Can I set a row-id column with the DATASET CREATELAYER?
Answer
Yes. The DATASET CREATELAYER has been modified in ArcInfo Workstation 8.2 to allow for setting a row-id column.
The default is SDESET, indicating the column is to be an SDE-maintained row-id.
When creating a layer from a dataset that contains a column named objectid, SDE uses that column as the row-id column by default.
Usage: DATASET CREATELAYER <dataset> <SDE_layer> <spatial_column> COVERAGE <cover> <feature_class> {spatial_idx_p
arams} {DBTUNE <keyword>} {anno_relate} {tin} {DEFINE} {<SDESET | USERSET> <column>}
Usage: DATASET CREATELAYER <dataset> <SDE_layer> <spatial_column> LAYER <defined_layer> {spatial_idx_params}{DBTUNE <keyword>} {anno_relate} {tin}
{<SDESET | USERSET> <column>} allows the user to control the column to be used for the object id.
Article ID:000004863
Software:
  • Legacy Products
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
