Frequently asked question
Can I import or save raster layer symbolization in ArcMap?
Answer
There is not an export/import option for the symbology that has been applied to a raster layer; therefore, the same symbology cannot be easily applied to other rasters. As a workaround, you can save the raster with the desired symbology to a Layer file using the Save As Layer File option. Use the Set Data Source button in the layer’s Properties Source tab to change the source for the Layer to a different raster dataset. The layer will then appear with the same symbology as the original. Repeat this process as necessary.
Article ID:000003227
Software:
  • ArcMap 8 x
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
