Frequently asked question
Can dynamic port allocation be used with SQL Server databases for the GIS Portal Toolkit?
Answer
No. The GPT uses Java Naming and Directory Interface (JNDI) strings to connect to the database. The port is specified as part of the connection information in the JNDI strings. Dynamically allocating ports voids the settings specified in the JNDI strings, and the GPT is not able to connect to the database.
If an instance of SQL Server was installed using dynamic port allocation, it is necessary to disable dynamic port allocation and apply a static port configuration instead. See the article in the Related Information below for how to do this.
SQL Server 2005 Express Edition is not supported for GPT 9.3.
Article ID:000010388
Software:
  • Legacy Products
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
