Frequently asked question
Can ArcGIS Server be installed on a domain controller?
Problem
Esri does not recommend or support running Esri Server-based software on a domain controller, because the function of a domain controller is to coordinate activities on a domain, not to serve as a Web server and application server. In most organizations, these are separate machines with very different functionality.
Domain controllers do not allow Local Users and Groups to be used once the server has been promoted to a domain controller. This may cause issues when running the post installation as it tries to create the ArcGISSOM, ArcGISSOC, and ArcGISWebServices accounts.
ArcGIS Server 9.2, 9.3, 9.3.1, and 10.0 can be installed on a domain controller. However, it is not recommended to do so. While 10.1-10.6.1+ are not supported to be installed on a domain controller.
Solution
Instead of deploying ArcGIS Server on a domain controller, consider an ArcGIS Server for Amazon Cloud-based solution which provides a scalable, fully functional ArcGIS Server solution without the infrastructure investment.
Article ID: 000010750
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
