An St_Geometry attribute can be dropped from a table in Oracle if the spatial index has been dropped first. If the spatial index has not been removed, the following Oracle error displays:
"ORA-29884: domain index is defined on the column to be dropped".
Cause: An ALTER TABLE DROP COLUMN was issued on a column on which a domain index exists.
Action: Drop the domain index before dropping the column.
Code:
SQL> ALTER TABLE rivers DROP (shape);
alter table rivers drop (shape)
ERROR at line 1:
For additional information, see the link to the Oracle Documentation in Related Information.
