Frequently asked question
Can a multiversioned view be deleted without leaving an entry in the table registry?
Last Published: August 6, 2025
ArcSDE software, including the application server, command tools, and SDK with C and Java APIs, was deprecated at ArcGIS 10.2.2 and is no longer distributed.
Yes. To delete a multiversioned view, always use sdetable -o delete_mv_view.
For -t, specify the name of the table or layer from which the view is created. For example, use the same value used in the -t option to create the multiversioned view. This procedure is shown below.
Code:
C:>sdetable -o create_mv_view -T shale_vw -t shale -i esri_sde -u sde -p sde
ArcSDE 9.1 Oracle10g  Build 407 Mon Mar  5 10:50:46 PST 2007
Attribute        Administration Utility
Successfully created MV view shale_vw for table shale.
C:\>sdetable -o delete_mv_view -t shale -i esri_sde -u sde -p sde
Delete MV view for table shale?
Are you sure? (Y/N): y
Successfully deleted MV view for table shale.
Using the above method, a multiversioned view can be created subsequently without issue, as shown below.
Code:
C:\>sdetable -o create_mv_view -T shale_vw -t shale -i esri_sde -u sde -p sde
Warning:
Using sdetable -o delete -t <view_name> leaves detached entries that associates the original table or layer with the multiversioned view in the table registry. This must be manually corrected. If it is not manually corrected, an error results if a multiversioned view is recreated. For example:
Code:
C:\>sdetable -o create_mv_view -T beach_vw -t beach -i esri_sde -u sde -p sde
Successfully created MV view beach_vw for table beach.
C:\>sdetable -o delete -t beach_vw -i esri_sde -u sde -p sde
Delete table beach_vw! Are you sure? (Y/N): y
Successfully deleted table beach_vw.
        Error: DBMS view exists (-238).
        Error: Unable to create MV view beach_vw for table beach.
When the above happens, use SQL to clean up the entry in the table registry as follows.
For Oracle, connect as the SDE user and run this update statement:
Code:
UPDATE table_registry
SET imv_view_name = NULL
WHERE table_name = 'BEACH' AND owner = '<owner of BEACH>'
For SQLServer, connect as the SDE user, or database operational (DBO) if using a DBO schema, and run this update statement:
Code:
UPDATE sde_table_registry
At version 9.2, the detached entry is cleaned up by ArcSDE.
Article ID: 000009475
Software:
  • Legacy Products
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
