Frequently asked question
Please note that VBA will probably raise a syntax error for the reference to IArcToolboxExtension. To fix this, add a reference to the ESRI Geoprocessing UI library. Do this using the Tools > References menu item.
Code:
Private Sub UIButtonControl1_Click()
'Ensure that there are references set to the
'ESRI GeoprocessingUI Object Library and the
'ESRI Geoprocessing Object Library.
'Go to Tools > References to do this
Dim pUID As New UID
pUID = "esriGeoprocessingUI.ArcToolboxExtension"
Dim pATBExt As IArcToolboxExtension
Set pATBExt = Application.FindExtensionByCLSID(pUID)
Dim pAtb As IArcToolbox
Set pAtb = pATBExt.ArcToolbox
Dim pTool As IGPTool
'* Use this line for custom tools or models
' Set pTool = pAtb.GetToolbyNameString("MyModel")
'* Use this line for existing tools
Set pTool = pAtb.GetToolbyNameString("buffer_analysis")
Dim pCommand As IGPToolCommandHelper
Set pCommand = New GPToolCommandHelper
pCommand.SetTool pTool
pCommand.Invoke Nothing
End Sub
Code:
Code:
Article ID:000007083
Get help from ArcGIS experts
Download the Esri Support App
