Frequently asked question
Can a .GRA or map composition be imported into a non-ESRI software application?
The .GRA and map composition are ESRI proprietary file formats that will not import into other non-ESRI software applications.
Convert the .GRA or map composition into another format, such as PostScript or bitmap, for use in other applications. Use the Arc command POSTSCRIPT for PostScript files or ArcPress for ArcInfo Workstation to export to a BMP, PCL, etc.
Article ID: 000007758
Software:
  • Legacy Products
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
