ERROR
TypeError: CalculateGeometryAttributes() takes from 0 to 5 positional arguments but 6 were given
First Published: August 12, 2020
Last Published: February 6, 2025
Error Message
When running the Calculate Geometry Attributes tool in a Python script, the following error may be returned:
TypeError: CalculateGeometryAttributes() takes from 0 to 5 positional arguments but 6 were given.
Cause
Prior to ArcGIS Pro 2.5, the Calculate Geometry Attributes tool only accepted 5 parameters:
in_features, geometry_property, {length_unit}, {area_unit}, {coordinate_system}
After the release of ArcGIS Pro 2.5., the tool now accepts 6 parameters:
in_features, geometry_property, {length_unit}, {area_unit}, {coordinate_system}, {coordinate_format}
When running the following line of code it is possible to find out how many parameters the tool accepts with the version in use:
arcpy.management.CalculateGeometryAttributes.__code__.co_argcount
Solution or Workaround
Upgrade to ArcGIS Pro 2.5. or later.
Article ID: 000023718
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
