HOW TO
Calculate Zonal Statistics for Overlapping Zones
Last Published: February 20, 2021
Summary
This article applies to retired ArcGIS versions 9.x and 10.0. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Instructions provided describe a sample Python script that can be used to calculate zonal statistics for overlapping zones.
When using polygon features as the input zones in the Zonal Statistics as Table tool, the tool rasterizes the vector features. This results in data loss if overlapping polygons are present in the zone feature.
Using Python, the tool's limitations can be overcome by iteratively processing each feature to overcome such a problem.
Procedure
import arcpy, os, sys, string
from arcpy import env
arcpy.CheckOutExtension("spatial")
def CreateDirectory(DBF_dir):
    if not os.path.exists(DBF_dir):
        os.mkdir(DBF_dir)
        print "created directory {0}".format(DBF_dir)
def ZonalStasAsTable(fc,DBF_dir,raster,zoneField):
    for row in arcpy.SearchCursor(fc):
        lyr = "Zone_{0}_lyr".format(row.OBJECTID)
        tempTable = DBF_dir + os.sep + "zone_{0}.dbf".format(row.OBJECTID)
        arcpy.MakeFeatureLayer_management(fc, lyr, "\"OBJECTID\" = {0}".format(row.OBJECTID))
        print "Creating layer {0}".format(lyr)
        out_layer = DBF_dir + os.sep + lyr + ".lyr"
        arcpy.SaveToLayerFile_management(lyr, out_layer, "ABSOLUTE")
        print "Saved layer file"
        arcpy.gp.ZonalStatisticsAsTable_sa(out_layer, zoneField, raster, tempTable, "DATA", "ALL")
        print "Populating zonal stats for {0}".format(lyr)
    del row, lyr
def MergeTables(DBF_dir,zstat_table):
    arcpy.env.workspace = DBF_dir
    tableList = arcpy.ListTables()
    arcpy.Merge_management(tableList,zstat_table)
    print "Merged tables. Final zonalstat table {0} created. Located at {1}".format(zstat_table,DBF_dir)
    del tableList
if __name__ == "__main__":
    ws = "C:/TEMP"
    DBF_dir = ws + os.sep + "DBFile"
    fc = "C:/TEMP/zone/zone_data/zones.gdb/zones"
    raster = r"C:/TEMP/zone/raster/zonalstat_DEM.img"
    zoneField = "ZoneID"
    zstat_table = DBF_dir + os.sep + "Zonalstat.dbf"
Article ID: 000011385
Software:
  • ArcMap 9 x
  • ArcMap 10 0
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
