HOW TO
The instructions provided can be used to calculate the total surface area of data stored using either the SQL Geography or the SQL Geometry data type in a SQL Server 2008 or SQL Server 2012 database. The syntax provided is executed using a query in SQL Server Management Studio (SSMS).
When used with the SQL Geography data type, the results of the STArea() are returned in squared units of the linear measure defined by the spatial reference system of the geography instance. When used with the SQL Geometry data type, the results of the STArea() are the squared units in which the coordinates were supplied.
So, if using a coordinate system where coordinate values are measured in meters, the area is measured in meters squared. If the coordinates were supplied in feet, the area is in feet squared.
> Select shape.STArea() as Area from sde.COUNTIES
Substitute the feature class to be measured for the one listed above as sde.COUNTIES.
![[O-Image] STArea1](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000011702/00N39000003LL2C-0EM39000000wdO2.png)
> Select shape.STAsText() as SHAPE_REAL from sde.COUNTIES
![[O-Image] STArea2](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000011702/00N39000003LL2C-0EM39000000wdO3.png)
Article ID: 000011702
Get help from ArcGIS experts
Start chatting now
