BUG
Calculate Field is failing when using join fields in the expression with PYTHON calculation types.
Example Code:
# Import system modules
import sys, string, os, arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
gp.overwriteoutput = 1
# Load required toolboxes...
gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Data Management Tools.tbx")
# Local variables...
population = "D:\\testdata\\Geodatabase.mdb\\population"
cities = "D:\\testdata\\Geodatabase.mdb\\cities"
Table_Name = "population_View"
population_View = "population_View"
population_View__2_ = "population_View"
population_View__3_ = "population_View"
# Process: Make Table View...
gp.MakeTableView_management(population, Table_Name, "", "", "CITY CITY VISIBLE;POP2007 POP2007 VISIBLE;Acres Acres VISIBLE")
# Process: Add Field...
gp.AddField_management(Table_Name, "Acres", "DOUBLE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
# Process: Add Join...
gp.AddJoin_management(population_View, "CITY", cities, "MB_NAME", "KEEP_ALL")
# Process: Calculate Field...
gp.CalculateField_management(population_View__2_, "population.Acres", "float(!SHAPE.AREA!/43560)", "PYTHON")
Python is interpreting the table name as a field name, and the field name as a parameter.
Article ID: 000009888
Get help from ArcGIS experts
Start chatting now
