PROBLEM
When the function SE_stream_calculate_layer_extent is executed against a versioned feature class stored using the SDO_Geometry (Oracle Spatial) type, an incorrect extent value is returned if there are any records in the Adds or Deletes tables that causes the layer extent to change.
The returned extent only refers to the geometries in the base table, not the Adds and Deletes tables. This is a known issue in 9.2.
Article ID: 000009078
Get help from ArcGIS experts
Download the Esri Support App
