When opening an mxd created in ArcGIS 10.0, a licensing error is encountered:
"You must register the following thematic layers before you can use them on your map."
Cause
An install path other than C:\Program Files\ArcGIS\Desktop10.0 was used when installing Business Analyst.
Workaround
The data source for the affected layers must be changed.
- Click 'Close' to exit after encountering the error message.
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000011245/00N39000003LL2C-0EM39000000wdGv.png)
- In the Table of Contents, open the group layers. Look for red exclamation marks that indicate broken layers.
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000011245/00N39000003LL2C-0EM39000000wdGw.png)
- Right-click one of the broken layers and select Properties.
- Click Source, and click the Set Data Source button.
Use the list below to create the new path to the layers.
Major Lakes -?\Program Files\ArcGIS\Desktop10.0\Business Analyst\Data\StreetMapData\hydro. Double-click on the Lakes_NA.sdc. Highlight Lakes_NA to add.
States labels (US) - : ?:\Program Files\ArcGIS\Desktop10.0\Business Analyst\Data\StreetMapData\census. Double-click on states.sdc to open it. Double-click on states_4 to add.
States border (US) - ?:\Program Files\ArcGIS\Desktop10.0\Business Analyst\Data\StreetMapData\census. Double-click on states.sdc to open it. Double-click on states_4 to add.
States labels - ?:\Program Files\ArcGIS\Desktop10.0\Business Analyst\Data\StreetMapData\census. Double-click on states.sdc to open it. Double-click on states_4 to add.
States labels (Regional) - ?:\Program Files\ArcGIS\Desktop10.0\Business Analyst\Data\StreetMapData\census. Double-click on states.sdc to open it. Double-click on states_4 to add.
Countries - ?:\Program Files\ArcGIS\Destop10.0\Business Analyst\Data\StreetMap\Background. Double-click on the nation.sdc and select nation_4.sdc.
County labels - ?:\Program Files\ArcGIS\Desktop10.0\Business Analyst\Data\StreetMapData\census. Double-click on the counties.sdc.
