HOW TO
Bulk update stored credentials for items in Portal for ArcGIS using the ArcGIS API for Python
First Published: May 24, 2024
Last Published: May 24, 2024
Summary
When there are a lot of services added to ArcGIS Enterprise with stored credentials, and those credentials get updates, it could be very time-consuming to update them manually.
Procedure
The below script automates updating the credentials by finding the items added to Portal for ArcGIS with stored credentials, and updating the credentials to the desired ones.
from arcgis.gis import GIS
gis = GIS("https://dns.esri.com/portal", "username", "password")
token = gis._con.token
content = gis.content.search(query="",max_items=10000)
def updateStoredCredentials(content):
    for item in content:
        if 'sourceUrl' in item:
            item = gis.content.get(item.id)
            properties = {"url":item['sourceUrl'],
                          "serviceUsername":"updatedusername",
                          "servicePassword":"updatedpassword",
                          "token":token,
            item.update(item_properties=properties)
            print(f"Successfully updated {item}")
Article ID: 000032506
Software:
  • ArcGIS API for Python
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
