BUG
Write permission is required on data for one-way replica
Write permission is required when creating a one-way replica.
Cause
Currently, a requirement for creating replicas is that the user creating the replica be granted write access on the data.
This should not be a requirement for one-way replicas.
Workaround
Using ArcCatalog, temporarily grant write access on the data to the user creating the replica and have the user create the replica.
  1. Connect to the database as the data owner.
  2. Right-click on the data that is to be replicated > Privileges.
  3. Type the user's name that is to replicate the data and check SELECT, INSERT, UPDATE, and DELETE.
  4. Click OK to apply these privileges.
  5. Once the replica is created, revoke the write access by right-clicking on the data as the data owner > Privileges > type the user's name > only check SELECT > click OK.
    Synchronization of data changes and schema changes subsequently succeed without the write permission.
Article ID:000010390
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
