BUG
Why do COSTALLOCATION, COSTDISTANCE and COSTBACKLINK fail when using floating point grid as the source grid?
If a floating point grid is used as the <source_grid> for COSTALLOCATION, COSTDISTANCE and COSTBACKLINK, an error message similar to the following will appear:"Grid: costalloc = COSTALLOCATION(srcgrd_flt, costgrd)
Source_grid SRCGRD must be of integer type to be used for allocation values.
Cost Distance mapping Failed
AML MESSAGE - Stopping execution of AML file due to ERROR condition"The Workstation documentation indicates that the <source_grid> can be integer or floating point for COSTALLOCATION, COSTDISTANCE and COSTBACKLINK. This is not correct.Floating point grids are not supported as input for the source grid.
Workaround
Article ID:000006423
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
