BUG
When zooming in to large scale and when features are created outside of the current extent, labels disappear on SQL created features
After inserting features using SQL (e.g., using an ST_GEOMETRY or SDO_GEOMETRY operator) and attempting to label the inserted features in ArcMap, the feature's labels disappear when zooming in to a large scale. This behavior occurs when the inserted features exist beyond the feature class extent. The issue impacts feature classes with ST_GEOMETRY or SDO_GEOMETRY storage types.For example:
Code:
DECLARE
v_registation_id number(8);
v_srid NUMBER(8);BEGIN SELECT registration_id INTO v_registation_id
FROM sde.table_registry
WHERE table_name = 'POLES'; SELECT srid INTO v_srid
FROM SDE.st_geometry_columns
WHERE (owner = USER AND table_name = 'POLES'); INSERT INTO roads (OBJECTID,LABEL,SHAPE) VALUES
(sde.version_user_ddl.next_row_id(USER, v_registation_id),
'ID_298',
sde.st_geometry('POINT ( 9689097.37142934 4423553.842365312)', v_srid)); COMMIT;
Cause
When inserting features with SQL (e.g., using ST_GEOMETRY or SDO_GEOMETRY operators), the feature class' extent is not automatically updated or expanded to include the new feature.
Workaround
After inserting features with SQL, recalculate the layer's extent by using the ArcSDE command sdelayer -o alter -E calc.
For example:
Code:
sdelayer -o alter -E calc -l poles,shape -i esri_sde -u username -p password
    Article ID:000010688
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
