BUG
TIFF images no longer georeference properly in ArcGIS 8.1.2 or higher
TIFFs that were georeferenced in ArcGIS 8.1 or 8.1.1 no longer georeference properly with ArcGIS 8.1.2 or higher.
Cause
This problem began with ArcGIS 8.1 or 8.1.1. Certain TIFF header tags are interpreted differently, particularly those related to projection and scale. When these tags are read into ArcMap 8.1.2 or higher, the rasters are scaled and referenced incorrectly and do not display in the original location.
Workaround
This can be fixed by using CONVERTIMAGE to edit the header information.
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/22490' target='_blank'>How To: Use CONVERTIMAGE to change or edit TIFF header information</a>
Article ID:000005328
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
