BUG
The single use version of the Data Interoperability extension does not appear to register properly
Using the 'direct' registration method in the ArcView or ArcEditor Single Use registration wizard to register the Data Interoperability extension alone appears not to work. The following message may appear:"Enter at least one valid registration number or choose not to register any extensions."
Cause
The registration wizard is not properly recognizing the data interoperability extension's authorization number.
Workaround
Follow the steps below.
  1. Click OK once the message appears.
  2. Click 'Back'.
  3. Select not to register any extensions.
  4. Complete the wizard and the Data Interoperability extensions register regardless.
Article ID:000007281
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
