BUG
The Repair Connectivity command fails with "Inconsistency with the network elements"
The Repair Connectivity command fails with the following message: "Inconsistency with the network elements".
Cause
There is an issue with one of the logical network tables that prevents the Repair Connectivity command from succeeding.
Workaround
This issue has been fixed in ArcGIS for Desktop 10.1.
There are two workarounds for this issue. The first is to drop and recreate the geometric network. The second is to run the Rebuild Network command on the geometric network. This should only be performed when working with Technical Support. Please contact Support to work on this issue.
    Article ID:000011392
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
