BUG
The ExportAixm51 function must be configured to support AirspaceActivation objects
When using the ExportAixm51 function to export Airspace features with Airspace.Activity_Code populated, the resulting AIXM 5.1 XML file contains Airspace.Activation entries without gml:id fields. When validating the output AIXM 5.1 XML file, XML validators report this missing field.
The ExportAixm51 config files also export Airspace.Activity_Code into AirspaceActivation instead of from Timesheet.Activity_Code, which is related to the Airspace primary feature.
This issue was resolved in ArcGIS version 10.8.1.
Cause
ExportAixm51 config files currently do not set a required gml:id field for output AirspaceActivation objects.
Workaround
Edit the 51ExportTemplate.xml file to add the gml:id attribute and the 51ExportRelationships.json file to source for the activity_code parameter from the time sheet.
  1. Navigate to the following directory:
C:\Program Files (x86)\ArcGIS\AviationCharting\Desktop10.7\DataExchange\AIXM\Exporter\51
  1. Edit the 51ExportTemplate.xml file, and search for the following code:
<aixm:activation>
           <aixm:AirspaceActivation>
             <aixm:activity>{activity_code}</aixm:activity>
           </aixm:AirspaceActivation>
         </aixm:activation>
  1. Replace the code in Step 2 with the following code, and save the file.
<aixm:activation>
      <aixm:AirspaceActivation removeIfOnlyAttributes="true" gml:id="asact_{timesheet.clientkey_id}">
       <aixm:activity>{timesheet.activity_code}</aixm:activity>
     </aixm:activation>
  1. Edit the 51ExportRelationships.json file in the same directory as Step 1. Add the following lines, under the time sheet header and within the airspace section (line 476).
"timesheet.activity_code",
"timesheet.clientkey_id"
  1. Add a comma at the end of the following line (line 475) as it is no longer the final statement in the fields section.
"timesheet.combtil_code",
This workaround is also detailed in BUG-000126617.
Article ID: 000022400
Software:
  • ArcGIS Aviation Airports
  • ArcGIS Aviation Charting
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
