BUG
The executed query is not executing correctly against the database. Verify the query syntax for your underlying database system.
Trying to find jobs by date or filter by date in a query against an Oracle JTX repository causes the following error message:
"The executed query is not executing correctly against the database. Verify the query syntax for your underlying database system."
Cause
The query generated by JTX is not a valid Oracle query.
Workaround
To format the date being searched, use the JTX SQL query functionality and the Oracle to_date or to_char function.
    Article ID:000010665
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
