BUG
The change version dialog box does not pop up when running post installation
The change version dialog box never appears and there are no errors thrown when running post installation on Windows 2000.
This only happens with SQL Express and project instances on Oracle or non-SDE.Default version.
Workaround
The JTX post installation can be run through the command line.
  1. Open command prompt from Start > Run. Type CMD and hit OK.
  2. Change the directory to the JTX Bin directory. For example: CD C:\Program Files\JTX\Bin.
  3. Enter the following command: JTXPostInstallation.exe /version:<yourdatabase.Version>
    For example, when trying to set it to the DBO.DEFAULT, enter /version:DBO.DEFAULT.
Article ID:000010736
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
