BUG
The background of an ArcMap Service is not transparent in ArcMap
When an ArcMap Service is added to ArcMap, the background of the service is no longer transparent even though there may have been no background color set for the service.
Cause
ArcMap is not registering the background of the ArcMap Service as transparent when the service is initially added to the map. This is true even if there was no background set for the service. In such cases white is the default background.
Workaround
To make the background of an ArcMap Service transparent, a new background color must be set for the ArcMap Service layer.
  1. An ArcMap Service is added, and the background is not transparent.
    The ArcMap Service Layer is the U.S. States.  The background of the ArcMap document the service is based on is the default white.  When the service is added to a map document with an existing layer the background of the ArcMap Service layer is not transparent.
    [O-Image] ArcMapService Background Not Transparent
  2. Right-click the ArcMap Service layer and select Properties.
  3. Go to the Advanced tab of the Layer Properties dialog box.
    The Advanced Tag of the Layer Properties dialog for ArcIMS Services
    [O-Image] ArcIMS Service Layer Properties Advanced Tag
  4. Click the Fill Color dropdown arrow and select Arctic White.
    Arctic White is in the top left corner.
    [O-Image] Color Picker Arctic White
  5. Keeping the Background transparent check box checked, click Apply.
  6. Click OK. The background of the ArcMap Service layer should now be transparent.
    The background of the ArcMap Service is now transparent.
    [O-Image] ArcMap Service Background Made Transparent
Article ID:000005162
Software:
  • ArcMap 9 x
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
