BUG
Note: BUG-000111603 was fixed in ArcGIS Pro version 2.5.
In ArcGIS Pro ModelBuilder, when using the Append tool with the 'Use the Field Map to reconcile schema differences' Schema Type, the field mapping is not preserved after saving and closing the model.
For example, in the image below, a new source NEWAHADI2 from the input dataset is selected and mapped to the output field AHA_ID. However, the model reverts to the default Field Map setting after saving and closing.
The behavior encountered is a software defect that is specific to ArcGIS Pro. For more information, refer to BUG-000111603.
As a workaround, select one of the following options:
Use the Append tool from the Geoprocessing pane
The image below shows the values appended to the Output Field successfully.
Use the Merge tool
While the Append tool combines input datasets to an existing target dataset, the Merge tool combines input datasets to a new output dataset.
Use the Append tool in ArcMap ModelBuilder
The image below shows the Field Map setting is preserved after adding a new source in the Field Map parameter.
Article ID: 000022112
Get help from ArcGIS experts
Start chatting now
