BUG
In version 10.5 of Portal for ArcGIS, when connected to the portal from a touch screen device, the Analysis button is unresponsive from the main menu or from a layer’s context menu.
This is a known issue. In a web map, pressing the Analysis button does not open the Perform Analysis panel on a touch screen device.
This issue is planned to be addressed in the 10.5.1 release of Portal for ArcGIS.
To allow users with touchscreen devices to perform analysis in version 10.5, the configuration file must be edited. This file is located on the machine where Portal for ArcGIS is installed. Click the following web help link to learn more about this file: Editing the configuration file for Portal for ArcGIS.
The instructions provided describe how to edit the configuration file for Portal for ArcGIS.
Note: Make a backup copy of your config.js file before modifying it.
Note: Unless the file has been edited, the following text should be added starting at line 559.
Article ID: 000015656
Get help from ArcGIS experts
Start chatting now
